Quest Maui Low Wattage Oil Filled Radiator - Black
Quest Maui Low Wattage Oil Filled Radiator – Black
£29.99 Inc VAT
Only 2 left in stock
SKU: 5060099877483 Categories: , , , , , ,
Looking for a low-wattage, oil-filled radiator?
The Quest Maui is great when extra heat is required during the colder days and evenings. Being low-wattage means it draws less electricity than a standard radiator, becoming cost-effective whilst also using less electricity whilst on a campsite, reducing the likelihood of causing a trip to the electric supply (Some sites only permit low-wattage electrical items)
Sporting a carry handle for ease of portability and 7 fins to help with heat dispersion, the Maui is a high-quality oil-filled radiator
The radiator has a thermostatic temperature control on it, which allows you complete control over the temperature. This allows you to turn the heat up or down and get to set just right for you.
  • Low wattage
  • High heat output
  • 7 Fins for good heat dispersion
  • Full temperature control
  • Overheat protection
  • Power indicator
  • Cord storage
  • Carry handle
  • Stability Feet
  • Pressure tested for additional safety
  • CE, GE, ROHS compliant
Specifications
  • Weight: 3.3 kg.
  • Size: 32 x 37.5 x 10 cm.
  • Cable Length: 140 cm.
  • Power: 800w.
  • Voltage: 220-240v
  • Frequency: 50/60hz.
Quest
Quest Leisure Caravan, Camping & Garden Centre supplier of all your accessories needs.
Be the first to review “Quest Maui Low Wattage Oil Filled Radiator – Black”
£29.99 Inc VAT
