Sale!
RidgeMonkey Classic XL Sandwich Toaster Inc Utensils - Granite Edition
RidgeMonkey Classic XL Sandwich Toaster Inc Utensils – Granite Edition
Original price was: £22.99.Current price is: £18.99. Inc VAT
Check out our full Ridgemonkey range –> Here  <–
Out of stock
Email Me When Back in Stock
The RidgeMonkey Classic Sandwich Toaster Granite Edition features fixed cool-touch handles, riveted hinges, and a full utensil set that fits inside the toaster for easy storage.
The square shape also means that there is less wasted storage space than with traditional circle-shaped cookware.
Despite the name, the Classic Sandwich Toaster is not just for toasties, think pies, slices, naans, wraps, omelets, and cinnamon swirls – the possibilities are endless.
The Granite coating makes the pans tougher, and more durable, offering improved non-stick properties: taking compact cookware to a whole new level.
The XL version is slightly bigger that the Standard but allows larger items to be cooked!
  • Granite-style coating with improved non-stick properties
  • 1 x fixed handle Pan
  • 1x heat-resistant utensil set
  • Lightweight aluminium construction
  • Sleek Gunmetal Grey finish
  • Ridged exterior for even heat transfer
  • Can be used on all traditional stoves and direct heat sources (not suitable for use on induction hobs)
Specifications
  • Approximate dimensions: 39.5cm x 20.5cm x 4cm (including handles)
  • Weight:620g
Type
With Standard Case, With Free Gorilla Case – Worth £19.99
Ridgemonkey
RidgeMonkey, brings to market a range of products that make a difference to anglers, campers, and outdoor living.
Be the first to review “RidgeMonkey Classic XL Sandwich Toaster Inc Utensils – Granite Edition”
You may also like…
  • RidgeMonkey DLX Standard Plate Set – Twin Pack
    Original price was: £12.99.Current price is: £9.99. Inc VAT
Subtotal: £2,559.23
View basketCheckout
