Sale!
RidgeMonkey Connect Sandwich Toaster Inc Utensils – Granite Edition
Original price was: £23.95.£19.99Current price is: £19.99. Inc VAT
Check out our full Ridgemonkey range –> Here <–
Out of stock
Email Me When Back in Stock
RidgeMonkey Connect Sandwich Toaster Inc Utensils (New Granite Edition)
Struggling for storage, or looking for a gift for someone? The Ridgemonkey Connect Sandwich Toaster is designed to be both versatile and small enough to store!
Featuring detachable cool-touch handles, a detachable hinge system that transforms one pan into two, and a full utensil set that fits inside the toaster, along with the handles, the Connect Sandwich Toaster is a brilliant addition to your camping or fishing collection.
The square shape means that there is less wasted storage space than with traditional circle-shaped cookware.
The Connect Sandwich Toaster is not just for toasties, think pies, slices, naans, wraps, omelets, and cinnamon swirls – the possibilities are endless.
The Granite coating makes the pans tougher, and more durable, offering improved non-stick properties: taking compact cookware to a whole new level.
- Granite-style coating with improved non-stick properties
- 2x flat-bottomed frying pans
- 1x heat-resistant utensil set
- 1x set of removable magnetic, thermoset plastic cool-touch handles
- 1x protective pan pouch
- Detachable hinge system
- Lightweight aluminium construction
- Sleek Gunmetal Grey finish
- Ridged exterior for even heat transfer
- Can be used on all traditional stoves and direct heat sources (not suitable for use on induction hobs)
Specifications
- Approximate Dimensions:18cm (29.5cm with handles) x 15.5cm x 4cm
- Weight:670g (full pan, including handles and utensils), 275g (each singular pan)
RM776
| Type | With Standard Case, With Free Gorilla Case – Worth £19.99 |
You may also like…
RidgeMonkey DLX Standard Plate Set – Twin Pack
Original price was: £12.99.£9.99Current price is: £9.99. Inc VAT
