Streetwize Yoga Battery Powered Grill
£65.99 Inc VAT
Out of stock
Email Me When Back in Stock
This portable charcoal BBQ grill is perfect for camping breaks, caravan & motorhome holidays, and al fresco dining. This BBQ grill doesn’t require you to connect to a mains power supply because it has a 4 x AA battery unit, but it also has a USB power socket if batteries are low or are depleted.
The battery unit is connected to an air fan that you can adjust to control the amount of heat from the charcoal easily and safely.
Quickly heats up; the battery-powered fan circulates the hot air around the BBQ so you can start cooking almost immediately!
  • Easily allows you to cook for up to 6 people
  • Supplied in a handy zip storage case
  • Up to 2 hours of grilling time
  • 4 x AA batteries required (not included)
  • 310mm ø cast iron rack
  • 345mm x 345mm x 240mm (boxed)
  • 5KG
LW602
Streetwize
Streetwize is one of the leading UK brands of top-quality leisure accessories and has become a well-known name in the automotive sector.
Be the first to review “Streetwize Yoga Battery Powered Grill”
You may also like…
  • Cadac 8mm Quick Release Coupling - Single
£65.99 Inc VAT
