HA70402 Swing Up Flap Hinge Mounting With Panel x 2
£4.99 Inc VAT
In stock
HA70402
HAFELE Bagged & Header Carded 1 x Large Swing Up Locker Flap Hinge.
Automatic closing and opening mechanism. Swing Up Flap Hinge, for Mounting with Panel, Opening Angle 90 degree. Caravan hinge for light flaps up to 2.1 kg Without soft closing mechanism. For maximum flap thickness: 15 or 16 mm, For flap width max. 800 mm, For flap height max. 340 mm. For flap weight Up to 2.1 kg. Approx 63mm (W) Closed (L) 72mm
PLS Hinge
HAFELE Bagged & Header Carded 1 x Large Swing Up Locker Flap Hinge. Automatic closing and opening mechanism. Swing Up Flap Hinge, for Mounting with Panel, Opening Angle 90 degree. Caravan hinge for light flaps up to 2.1 kg Without soft closing mechanism. For maximum flap thickness: 15 or 16 mm, For flap width max. 800 mm, For flap height max. 340 mm. For flap weight Up to 2.1 kg. Approx 63mm (W) Closed (L) 72mm
Pennine Leisure Supplies
Caravan, Motorhome, Campervan Conversion and Camping Accessories, Spares & Leisure Appliances.
Be the first to review “Swing Up Flap Hinge Mounting With Panel x 2”
You may also like…
  • VW T5 T6 T6.1 California 19" 12v / 240v Smart TV Package
  • Campervan Fire Extinguisher with Bracket
  • Gallant ‘Lift Off’ TV Bracket for - VW T4 T5 T6 T6.1 California, Caravelle, Campervan, Ford Transit Custom Nugget
  • Caraloc 640 Caravan Front & Standard Barrel & 2 Keys
    Original price was: £12.99.Current price is: £9.99. Inc VAT
£4.99 Inc VAT
