Sale!
Tear Aid Fabric and Drive Away Awning Repair Kit (Type A)
Tear Aid Fabric and Drive Away Awning Repair Kit (Type A) Poptop Repair
Original price was: £10.49.Current price is: £8.99. Inc VAT
In stock
If you have a hole in your roof bellows/canvas or drive away awning, this is ideal for a quick yet efficient repair.
Made from ultra-high-strength clear polyurethane polymer, offering a watertight seal.
  • Permanent repair – no welding/separate adhesives
  • Repairs Holes And Tears Instantly
  • UV Resistant Inhibits Yellowing
  • Cuts Easily To Any Size With Scissors
  • No special skills needed – just thoroughly clean and dry the area to be repaired
  • Cut strip to suit length of tear, peel off backing and apply. Full strength adhesion in minutes! Ultra high-strength clear polyurethane polymer
  • Only needed on one side of repair
Our Package Includes:
  • 1 x  – 300mm x 75mm patch ( can be cut to size)
  • 1 x – 35mm x 35mm patch
  • 1 x – 22mm x 22mm patch
  • 1 x  12″ Reinforcement Filament for repairing tears at edges
  • 1 x  Instruction set
Materials that this Tear Aid  will be suitable for:
  • Canvas
  • Leather (non-oiled)
  • Rubber
  • Nylon
  • Most Plastic & Paints
  • Plastic Laminates
  • Aluminium
  • Stainless Steel
  • Fibreglass
  • Polyurethane
  • Polyethylene
  • Polypropylene
  • Sunbrella
  • Gortex
  • Acrylics
  • Polyester
  • Hypalon
  • Dacron
100% Genuine – Made in the USA
Weight .100 kg
Dimensions 36 × 35 × 6 cm
Be the first to review “Tear Aid Fabric and Drive Away Awning Repair Kit (Type A) Poptop Repair”
You may also like…
