Thule VeloSpace XT 2 Tow Bar Tilting Bike Carrier - 2 Cycles
Thule VeloSpace XT 2 Tow Bar Tilting Bike Carrier – 2 Cycles
£689.99 Inc VAT
Find the XT 3 ->HERE<-
Whether you have mountain bikes, children’s bikes, or e-bikes to carry with you on your travels, the Thule Velospace is a great bike carrier, attaching securely to your tow bar.
With an impressive tilting function, you can tilt the bike rack to gain access to your boot with the bike racks attached. –> This can be used with the VW T5, T6 & T6.1 but it will not allow the rear tailgate to open with bikes in situ, for this you will need the VeloSpace XT3
Although the maximum capacity is 60kg overall, a single bike should not weigh more than 30kg.
  • Extra-long wheel trays to enable transport of large bikes (up to 1300 mm wheelbase).Extra-wide between wheel holders (25 cm) for the easiest mounting of sturdy bikes
  • Easy mounting and adjustment of the bike rack before closing the tightening handle, thanks to the towbar coupling’s initial stability
  • Combine with Thule BackSpace XT to create an all-round cargo carrier, giving the car 300L of easily accessed, extra loading space
  • Possible to increase the load capacity to 3 bikes by adding Thule VeloSpace XT Bike Adapter
  • Easy trunk access even with bikes mounted, thanks to smart foot pedal tiltLock your bikes to the bike rack and your bike rack to the towbar (locks included)High load capacity enabling transport of e-bikes and heavy mountain bikes
  • Adjustable pump buckles with extra-long wheel straps for easy fastening of wheels (up to 4.7″ wheels) enabling transport of fat bikes
  • Easy mounting of bikes through detachable bike arms with Thule AcuTight torque limiter knobs that click when optimal torque is reached
Bike Rack Specifications
  • Dimensions: 135 x 69 x 79 cm
  • Folded dimensions: 135 x 74 x 25 cm
  • Weight: 18.7kg
  • Power connector: 13-pin
Loading Specifications
  • Maximum Load Capacity: 60kg
  • Max bike weight: 30Kg
  • Maximum Wheel Size: 29″
  • Distance between bikes: 25cm
  • Fits frame dimensions: 22-80mm
938021
Instruction Symbol Vector Images (over 31,000)
Please allow 3-5 days for delivery – Delivery only to mainland uk.
Thule
Thule is a Global market leader in a number of product categories, including roof racks, roof boxes, and bike racks
Be the first to review “Thule VeloSpace XT 2 Tow Bar Tilting Bike Carrier – 2 Cycles”
£689.99 Inc VAT
Subtotal: £18.49
View basketCheckout
