Thule Wingbar Evo 118cm – Pack of 2 – Aluminium
£90.00 Inc VAT
Only 1 left in stock
Found this item cheaper?
PLEASE NOTE: Bars Only, Fitting Kit will need to be purchased separately.
Premium aerodynamic load bars for an exceptionally quiet ride and easy installation of accessories. 2-pack.
At the Thule Test Center™ in Hillerstorp, Sweden, products go through extreme testing. Thule roof rack systems are designed to carry your gear and fit your car as safely and securely as possible.
The 3 main tests carried out are; crash tests, wear and tear simulations & exposure tests.
- Load bar for Thule Evo roof rack system
- WindDiffuser technology disturbs airflow to reduce noise and drag for improved fuel economy
- TrailEdge design reduces aerodynamic drag by allowing clean air separation from bar
- SmartSlides slidable length scale doubles as an under-bar aerodynamic cover, providing quick, no-hassle rack installation
- SwingBlade end cap pivots open to allow full access to the T-slot for easy accessory installs
- Upper T-track with QuickAccess interface allows smooth installation and removal of accessories
- BoxBeam internal structure creates an exceptionally strong load bar
- Loading Width: 118cm
- Loading Length: 118cm
- Maximum Load: 100kg
Be the first to review “Thule Wingbar Evo 118cm – Pack of 2 – Aluminium” Cancel reply
