Travellife Bodin Foldable Grey Storage Box - Small
Travellife Bodin Foldable Grey Storage Box – Small
£19.99 Inc VAT
In stock
With the small, dark grey Travellife foldable storage box, you can easily organise your belongings. The small storage box is made of solid plastic and features a stackable design.
The storage box features a stackable design and has a carrying capacity of 30 kg.
Fully unfolded, the box measures 41 x 29.5 x 22 cm. The box can be folded to a compact size of 41 x 29.5 x 5 cm.
All Travellife Bodin storage boxes feature a thicker bottom, allowing the boxes to be stacked perfectly. You don’t have to worry about the boxes sliding off each other during the journey.
In a camping vehicle, you don’t want too many loose items lying around. The Bodin foldable storage box in dark grey is ideal for this. You can easily assemble the storage box yourself. Because the storage box can also be opened on the sides, you can place it anywhere. If you need to grab something quickly, you can access the box using the slides on the side without needing to open the lid fully.
Have an awning? The boxes can be easily transported meaning you can remove them from the van to store in your awning when parked!
Main benefits
  • Solid multifunctional plastic storage box
  • Compactly foldable
  • Easy stackable
  • Can be opened from the top and the sides
  • Carrying capacity: 30 kg
Specifications
  • Built – 41 x 29.5 x 22cm
  • Folded – 52 x 29.5 x 5cm
  • Weight – 1.4kg
  • Maz Carry Weight – 30kg
Looking for something larger –>
Travellife
Be the first to review “Travellife Bodin Foldable Grey Storage Box – Small”
£19.99 Inc VAT
