Vango Airbeam Tempest Rechargeable Pump
£79.99 Inc VAT
Out of stock
Email Me When Back in Stock
Designed for not only the Vango Air Awnings and Tents, but also other brands such as Outwell, Outdoor Revolution, and Kampa; the Vango Airbeam Tempest is a rechargeable pump which is easy to handle and store.
Features include an LED screen, a USB output port, a variety of adaptors, and a built-in auto cut-off that automatically stops when it reaches its set pressure, which makes setting up alot more efficient.
The Airbeam Tempest also features a two-stage motor designed to increase airflow, allowing quick inflation or deflation of your tent, awning, or other inflatable camping gear.
What am I compatible with?
  • Any Self-Inflating Mat (SIM) with a Cyclone Valve
  • Bravo Adaptor – Compatible with several other inflatable tents
  • Boston Adaptor – Compatible with a variety of other inflatable products
  • 130cm Hose with Multiple Adaptors – Provides versatility to inflate a range of product
  • Inflates and Deflates – Quick and easy for a simple set-up and a fast pack-up
  • USB cable included – charge directly from any standard USB port
  • Rechargeable Lithium Battery 2000mAh/90W – Never have to buy batteries again
  • Inflates to Max 10PSI with Auto Cut Off – Perfect for inflating tents, awnings and inflatable chairs
  • 2 Stage Motor – Airflow 500L/Min & 40L/Min – Gives increased airflow in to your product which means the beam or the product will be able to inflate faster
  • Charging Time – 5V2A – 3 hours & 9V2A – 2 hours
  • Runtime – 30 mins – Ensures you get all of your equipment set up for your camping trip
  • Working Noise = 75db – Quiet inflating device which won’t disrupt other people on the campsite
  • Power Bank Function – Rechargeable via USB-C, with a USB output port. (Charging cable included).
  • LED Display Screen – Allows you to see how inflated your equipment is on the screen
Specifications
  • Weight 1.06kg
  • Height 9.2cm
  • Width 8.7cm
  • Length 26.4cm
ACVPUMP00000001
Vango
Be the first to review “Vango Airbeam Tempest Rechargeable Pump”
£79.99 Inc VAT
Subtotal: £450.91
View basketCheckout
