Vango Apex 200 Compact Tent - 2 Person Tent
Vango Apex 200 Lightweight Compact Tent – 2 Person Tent
£124.99 Inc VAT
Out of stock
Email Me When Back in Stock
SKU: 5059474014391 Categories: , , Tag:
Introducing Vango’s exciting, lightweight, and innovative Apex Series, designed for adventurers who need a compact, high-quality, lightweight tent.
As part of Vango’s Earth Collection, the Apex is made using 70D Protex® Eco fabric, created from recycled single-use plastics.
Unique to Apex is the 30cm pole sections, which make it ideal for packing light on any adventure, from mountaineering, hiking, and Duke of Edinburgh’s Award activities to bike packing, as its unique pack design can attach to bike handlebars.
The Apex makes excellent use of your available space and has a number of other features, from strong PowerLite Alloy Poles, part mesh doors for ventilation in summer or use abroad, and O-Shaped Doors that make it easy to open with one hand and also frame those views.
  • Tunnel tent construction – A quick and easy-to-pitch design that reduces overall weight without compromising on internal volume
  • All-In-One Pitching – Quick and easy to pitch and pack away by leaving the inner clipped into the flysheet. It can also be pitched flysheet-first without the inner to provide a simple shelter.
  • Compact PowerLite Alloy Poles – Lightweight and durable poles made from 7001-T6 aluminium that balance weight and strength. Shorter pole sections reduce overall pack size
  • Protex Eco Ripstop Flysheet – Created from recycled single-use plastics to reduce our environmental footprint, this 68 denier ripstop polyester is waterproof to 3000mm HH and has fully taped seams, providing durability and reliability for camping in all conditions.
  • Inner tent made from durable polyester and breathable mesh to increase ventilation and reduce condensation for a comfortable night’s sleep
  • Durable 70D PU backed polyester groundsheet that’s durable and easy to clean with a waterproof 6,000mm HH rating
  • Bathtub groundsheet that extends 10cm up the inner tent to keep you dry in harsh weather
  • TBSII – Unique to Vango tents, our Tension Band System creates a triangulated shape inside the tent to brace against strong and changeable winds and reduce sideways deformation. TBSII is easy to adjust and can be securely stowed when not in use.
  • High-visibility reflective guylines that are easy to see in low-light conditions
  • High-grip guyline adjusters securely hold tension in even the harshest conditions and can be easily adjusted with one hand
  • Lightweight aluminium alloy pegs
  • Fully Taped Seams – All flysheet and groundsheet seams are factory taped for a watertight seal
  • O-shaped inner doors allow a smooth zip motion that can be opened with one hand
  • Partial mesh inner door ensures maximum airflow whilst keeping out bugs
  • Rain Stop flysheet doors are designed to stop rain dripping into the inner when opened
  • Mesh-covered vents at each end of the flysheet allow air to flow through and reduce condensation
  • Single porch provides covered storage space for your kit
  • Fast Pack tent bag with an oversized opening design makes it easier to pack away. Rolltop closure and compression straps keep pack size to a minimum and can easily be attached to bicycle handlebars.
  • Internal Storage Pockets – Provides convenient storage within the inner tent, keeping essentials close to hand
  • Fully Rain Tested – Weather tested to standard EN ISO 5912 for peace of mind. This tent is suitable for use in wet and windy weather. Cautionary level storms and extreme weather should be avoided
  • Fire Retardant Fabrics – Meets European EN5912 safety standard
Specifications
  • Pitching Time 5mins
  • Capacity 2 Person Tent
  • Trail Weight 1.99kg
  • Fabric Protex Eco
  • Pack size 33.0 x ⌀15.0cm
  • Waterproof Rating 3000mm HH
TEVAPEX00000003
FIND THE PITCHING INSTRUCTIONS –> HERE <–
Looking for a slightly smaller version? Find the 2-Person version here –>HERE<–
Vango
Be the first to review “Vango Apex 200 Lightweight Compact Tent – 2 Person Tent”
£124.99 Inc VAT
