Sale!
Vango Atlas 250 Quad Sleeping Bag – Black
The Atlas 250 Quad is perfect for festival-goers and those taking their first step into the world of camping.
This 2-season sleeping bag, with its TOG rating of 8.5, soft Polair® fabric with single-layer stitch construction and shaped hood, makes it an incredible value for money.
The Atlas 250 Quad is the perfect sleeping bag for novice adventurers who want a cosy night’s sleep under the stars.
- Grade A Quality Fill – Superior fibre fill which is designed to be durable, warm and lightweight, while retaining its loft and soft touch
- Independently Tested – Gives you reassurance that the temperature ratings are accurate ISO 23537-1:2016
- Hanging Loops – Allows you to easily hang your bag for quick and easy drying
- Single-Layer Stitch Construction – Reduces cold spots by ensuring the fill is evenly distributed within the bag
- Woven Zip Puller – Allows you to quickly and easily move the zip
- Two-Way Zip – Can be unzipped from the top or bottom to increase ventilation
- Polair Shell – Smooth to touch, hardwearing and washable Polair polyester fabric (190T)
- Polair Lining – Super soft lining which is also hardwearing and easily washable, Polair polyester
- ThermoLock Insulation – Provides warmth and retains loft in damp conditions
- Insulation Lock – S-Stitching holds insulating fibre in place for an even distribution across the body
- Stuffsack with Drawcord – Allows for easy packing, while minimising pack size for easy transportation
- Shaped Hood with Drawcord Closure – Reduces heat loss from the head. Drawcord allows adjustment of the hood for controllable heat retention
- Colour Contrasting Zipper – Vibrant, contrasting colour nylon zip
- Square Shaped Bag – Also known as an envelope shape sleeping bag. Provides generous internal space for freedom of movement and comfort
Specifications
- Season: 2 Season
- Weight: 1.423kg
- Shape: Square
- Zip Side: Left
- Suggested Usage: Min 6°C
- Comfort: 6°C
- Suggested Usage Max: 20°C
- Int Length: 195cm
- Int Chest Width: 78cm
- Int Foot Width: 78cm
- Max User Height: 185cm
- Fill Type: 30% Single Hole siliconised hollow fibre/70% polyester fill
- Limit: 1°C
- Extreme: -14°C
- Tog: 8.5
SBTATLAS0000006
Original price was: £26.99.£19.99Current price is: £19.99. Inc VAT
![the-original-insulated-blanko-limited-edition-design-olpro__14943.1739966206[1]](https://vwcaliforniaclub.com/shop/wp-content/uploads/2025/03/the-original-insulated-blanko-limited-edition-design-olpro__14943.17399662061.png)
