Vango Awning & Tent Universal Carpet 240 x 300cm – CP007
PLEASE NOTE: This carpet can also be used in the Vango Magra which measures 200 x 298cm, meaning it will have an excess of 40cm which can be folded underneath.
Make your awning nice and cozy by adding warmth and comfort underfoot with a Vango Carpet. This universal carpet is 240 x 300 cm.
Can be used in several tents and awnings if you just want a bit of carpet in certain areas or if the area you have is 240 x 300cm.
This Vango Universal Carpet is 240 x 300 cm making it ideal for the following Vango Tents and drive-away awnings:
  • Hogan Hub
  • Bondi Low
  • Capri II Air 500XL
  • Stanford II 850XL
  • Byron Low
  • Siesta Low
  • Elwood Low
  • Hudson 500XL
Please note this carpet is universal and is not made to fit these tents exact.
  • Neutral colourway to suit all.
  • Corner branding for easy positioning and identification
  • Woven nylon top for durability
  • Foam mid-layer for added insulation and comfort
  • PE waterproof, non-slip base
  • Easy to clean – Can be brushed, vacuumed or cleaned with a damp cloth if required
  • Supplied with a handled carry bag
  • Size: 240 x 300cm
CPQ000007W11G28
Weight 2.25 kg
Dimensions 38 × 25 × 34 cm
Vango
Be the first to review “Vango Awning & Tent Universal Carpet 240 x 300cm – CP007”
You may also like…
  • Tent Pegs, Bag and Mallet Kit
£42.95 Inc VAT
Subtotal: £44.99
View basketCheckout
