Vango Combi IR Compact Camping Double Grill Gas Cooker
£49.95 Inc VAT
Only 1 left in stock
If you are a keen outdoor chef, the Vango Combi IR Grill Compact is ideal. This 2-burner, compact stove with infrared grill offers high heat output whilst remaining low on fuel consumption. With compact, easy storage and anti-slip feet, this grill is the perfect partner for dining al fresco.
  • 0.6KW Infrared Grill – Ensures low fuel consumption, whilst generating high heat output. Saves 10% on fuel and 90% reduction on emissions for a cleaner cooking experience
  • Brass Flame Control Valves – Each burner has its own individual control valve, allowing you to use different heat levels for varying types of food
  • Chrome Steel Burner Grate – A high quality burner grate to support your pots and pans
  • Lid Locks – These keep the grill firmly closed when not in use or when away in storage so nothing can get lost or damaged
  • Anti-Slip Feet – 4 anti-slip feet help keep the grill in place on its surface to minimise the risk of accidents
  • 2 x 1.4KW Stainless Steel Burners – Two high quality 1.4KW, easy to clean stainless steel burners for cooking several foods at once
  • Windshield with Lid Locks – Helps reduce cooking times by shielding from draughts and wind
ACNCOMBI H09M1E
Vango
Be the first to review “Vango Combi IR Compact Camping Double Grill Gas Cooker”
£49.95 Inc VAT
