Sale!
Vango Cove III Low Poled Drive-Away Awning - 2025 Version
Vango Cove III Low Poled Drive-Away Awning – 2025 Version
Original price was: £429.00.Current price is: £339.00. Inc VAT
Only 1 left in stock
Perfect for couples and young families, the Cove is a compact awning that provides valuable extra space on weekends away. It now features additional multiple ventilation panels, allowing you to control your comfort levels. Featuring lightweight Powerflex poles and Vango’s Sentinel Active 75D fabric, ensuring a compact pack size leaving you with more room in your campervan for your camping essentials. With space to clip in a Drive Away Awning Bedroom should guests come to stay, and a pre-attached front canopy, this versatile drive away awning will be a staple to expand your livable space on any trip. Featuring a front-facing layout, the Cove is positioned the same way as your campervan, ensuring you are always facing the view and giving you added privacy from your campsite neighbours. The ideal addition to your campervan for wherever your next adventure takes you.
  • Sentinel Active 75D – Lightweight, compact and waterproof. 75D fabric with an HH rating of 3,000MM.
  • Vango PowerFlex Fibreglass Poles – Creates strong, light and reliable structures
  • Sewn-in Groundsheet – Provides a bug and draught-free environment. Groundsheet is attached to the flysheet with an external storm skirt to give all-round protection
  • Pre-Attached Front Canopy – Provides shelter from all weathers and is ideal for socialising
  • An extra ventilation panel to allow for increased ventilation and improve comfort.
  • Drive Away – Using the addition of a Drive Away Kit, detach the tunnel area of your awning from your vehicle and roll it away leaving your awning free-standing as you explore for the day.
  • Easy Access Doors – A flat entry access door creates easy access for wheelchairs, prams and people with reduced mobility
  • Two Doors in Tunnel Attachment to Vehicle – For convenient access to the front or back of your vehicle
  • Diamond Clear Windows – Maximise light and visibility to provide a bright and airy environment
  • Toggled Privacy Curtains – Easy to use privacy curtains that can be simply rolled away when not in use
  • Easy Pack Carry Bag – Oversized carry bag to make it easier to pack the awning away
  • Tunnel Adjustment Strap – Helps collect any excess material and creates a neater looking tunnel and a tighter fit to the vehicle
  • Supplied with Steel Pegs – Strong and durable pegs ideal for grass pitches. Supplied with a handy carry bag
  • TBSII Tension Band System – Ensures awning performs in adverse conditions, especially in strong, changeable winds. When tensioned, the bands brace the beam or pole at 3 points and prevent sideways movement. Adjust TBSII to remove slack. Do not over-tension, as this may deform the poles. Can be stowed away in calm weather
  • Roll Away Connecting Tunnel – Detach your awning when you drive away for the day, simply roll back the tunnel and toggle it to secure
  • Side Attachment – Awning attaches to your van with a side attachment to ensure you are always facing the view wherever you go
  • Multiple Vehicle Attachment Methods – All our awnings come with pre-attached 6mm kador, 8M over vehicle straps, roof bar attachment tabs and a sleeve for the pole & clamp kit system. This ensures our awnings are compatible with any vehicle
  • Touring Awning – This awning is designed for touring use; it is not designed for static or long-term seasonal pitching as extensive exposure to UV light will cause accelerated fabric degradation. UV degradation is not covered under the warranty. However, under normal holiday use your awning will give long service
  • Fully Wind and Rain Tested – Tested with wind and heavy rainfall to the European standard EN5912
  • Mesh Front Door – Fitted with internal mesh fly screen for bug-free ventilation
  • Clear Visibility Guylines – Bright coloured guylines for clear visibility to prevent tripping hazards and ensure stability in high winds.
  • Key pegging points are highlighted in orange. Pitch these points first to create the correct shape of your awning. Thereafter errect your tent.
  • Expand your sleeping/storage space within your awning by using the optional inner bedroom.BR001 – 2 person / BR005 – 4 person.
Specifications
  • Weight 13.9kg
  • Depth 310.0cm
  • Height 205.0cm
  • Width 320.0cm
  • Pitching Time 10mins
  • Kador Length 260cm
  • Kador Height 180-210 (Low)cm
  • Fabric Sentinel A
  • Connection Width 240cm
  • Pack size (Bag 1) L68.0 x H27.0 x W29.0cm
  • Bag Weight 13.0kg
  • Rail Weight 6.7kg
AWVCOVEPO000001
2 person inner bedroom -> https://vwcaliforniaclub.com/shop/product/vango-drive-away-awning-inner-bedroom-midnight
Vango
Be the first to review “Vango Cove III Low Poled Drive-Away Awning – 2025 Version”
