Vango Galli CC II Air Mid Drive Away Awning – Roof Rail Connection Height: 215-255cm – Kador Length – 260cm
The Vango Galli CC II  is an updated model of the previous well-known Vango Galli CC. The main difference is that the 2024 version is now made out of the Sentinel Active 150D Fabric rather than the standard, meaning the fabric is a thicker and stronger fabric.
The new and improved sentinel 150d version of the Vango Galli CC is ideal for anyone who wants a large and versatile space on their outdoor holiday and is ideal for family breaks. The pre-attached canopy also makes for a great space to relax outside, no matter what the weather.
Created using Vango Sentinel Active 150D fabric, it blocks out more light and is slightly heavier than the previous fabric although remaining very lightweight in comparison to other similar sized awnings.
The AirBeam structure allows for fast and easy pitching with a strong and reliable structure. Vango’s patented Tension Band System provides extra stability in windy conditions. Multiple vehicle attachment options also make set up easy whilst the roll-away tunnel allows you to drive away, leaving the Galli free-standing when you go exploring for the day.
The Galli CC II comes supplied with steel pegs, an airbeam pump and pre-attached guylines.
  • Sentinel Active 150d Fabric
  • Inflatable Airbeam Structure
  • Pre-attached Front Canopy
  • TBS II Tension Band System
  • Diamond Clear Windows
  • Mesh Front Door
  • Clear Visibility Guylines
  • Easy Access Doors
  • Tunnel Adjustment Strap
  • Toggled Privacy Curtains
  • Sheltered Entry
  • Easy Pack Carry Bag
  • Lantern Hanging Points
  • Wind and Rain Proof Tested
  • Side Attachment
  • Sewn-in Groundsheet
  • Roll Away Connecting Tunnel
  • Two Doors in Tunnel Attachment
  • Airzone Ventilation
  • Multiple Vehicle Attachment Options
Specifications
  • Total Weight: 22.9kg
  • Packsize: L 74cm x H 45cm x W 45cm
  • Pitching Time: Approx.15 minutes
  • Kador Adjustable Height: 215-255cm
  • Height: 210cm
  • Length: 555cm
  • Depth: 320cm
AWUGALLAI000002
Please allow 3-5 Days for Delivery on this item.
Weight 30 kg
Dimensions 78 × 44 × 39 cm
Vango
Be the first to review “Vango Galli CC II Air Mid Drive Away Awning”
You may also like…
  • Vango Galli III, Galli III TC & Rhone Awning Carpet – CP100
  • Vango Drive Away Awning Kit 6mm to 6mm (3m Length)
    Original price was: £21.99.Current price is: £18.99. Inc VAT
  • Vango Drive Away Awning Inner Bedroom - Midnight BR001
  • Vango Magra Footprint Groundsheet
£939.99 Inc VAT
