Vango Kela PRO Air Low Driveaway Awning - 180-210cm
Vango Kela PRO Air Low Driveaway Awning – 180-210cm
£749.00 Inc VAT
Check Out The Full Vango Pro Driveaway Collection –> Here <–
Looking for an awning that will pitch in minutes, whilst offering a great additional space to your camping setup with your campervan or VW California?
The Vango Kela PRO is designed to attach effortlessly to the side of your vehicle, has 4 attachment options and the tunnel space creates the ideal storage area or corridor, so you can keep your awning and vehicle clean and dry.
Two integrated air beams and a small porch pole provide shelter quickly over the side door, taking just 8 minutes to pitch!
Both the main door and side door have additional mesh doors for use in warmer weather and there is a large diamond clear window on the other side provided with attached privacy curtains.
The Vango Kela Pro uses the latest Eco Pro Fabric made from recycled materials whilst still maintaining the durable 420D double ripstop performance with ColourLok technology to reduce UV fading.
A two-person bedroom inner (optional extra) can be clipped in on one side of the awning and the front door can be extended into a sun canopy using a pair of king porch poles (optional extra).
  • Sewn-in Groundsheet – Provides a bug and draught-free environment. Groundsheet is attached to the flysheet with an external storm skirt to give all-round protection
  • Eco Pro Fabric – Robust, durable, and waterproof. Featuring 420 double ripstop threads with an HH rating of 6,000MM. Made using recycled single-waste plastics to continue Vango’s commitment to sustainability.
  • ColourLok™ technology to aid color retention.
  • Diamond Clear Windows – Maximise light and visibility to provide a bright and airy environment
  • Secondary Mesh Doors – Fitted with internal mesh fly screen for bug-free ventilation
  • Zipped Privacy Curtains – Simple and quick to use, zip curtains allow varying levels of opening or simply roll down and secure away
  • King Pole Door – The Door can be used as a canopy by adding additional king poles through the door eyelets, providing shelter from sun or rain
  • Cable Entry Point – Neatly feed electrical cables into your awning allowing you to easily keep your camping appliances powered
  • TBS®II Tension Band System – Ensures awning performs in adverse conditions, especially in strong, changeable winds.
  • Two Doors in Tunnel Attachment to Vehicle – For convenient access to the front or back of your vehicle
  • Tunnel Adjustment Strap – Helps collect any excess material and creates a neater-looking tunnel and a tighter fit to the vehicle
  • Roll Away Connecting Tunnel – Detach your awning when you drive away for the day, simply roll back the tunnel and toggle it to secure
  • Reflective Webbing – Picks up torchlight so the pegging points are easily spotted in low-light conditions
  • Adjustable Pegging Points – Allows awning to be pitched perfectly on uneven surfaces
  • Reflective guylines with Line-Lok runners – Lock securely, simple to release, and high performance in all conditions
  • Fully Wind and Rain Tested – Tested with wind and heavy rainfall to the European standard EN5912
  • Carry Bag
Specifications
  • Weight 19.3kg
  • Depth 370.0cm
  • Height 213.0cm
  • Width 310.0cm
  • Pitching Time 8mins
  • Kador Length 248cm
  • Kador Height 180-210cm
  • Hand Pump Inflate Time 2mins
  • Pack size L90.0 x H42.0 x W32.0cm
  • Rail Weight 15.0kg
AWTKELAPR000003
Please allow 3-5 Days Delivery on this item.
Vango
Be the first to review “Vango Kela PRO Air Low Driveaway Awning – 180-210cm”
£749.00 Inc VAT
Subtotal: £29.99
View basketCheckout
