Sale!
Vango Magma Gas Double Camping Cooker
Original price was: £69.99.Current price is: £64.99. Inc VAT
Out of stock
Email Me When Back in Stock
The Vango Magma Cooker offers high heat output from its dual 3kW burners, whilst remaining low on fuel consumption thanks to the self regulating hose provided
With piezo ignition and individual heat controls, the Magma Cooker is quick and easy to set up
Compatible with EN417 Gas cartridges.
  • Chrome Steel Burner Grate – A high quality burner grate to support your pots and pans and allow air to circulate
  • Foldable Frame with Carry Handle – The grill folds into itself forming a small, portable cooker with carry handle for easy transportation
  • Lid Locks – These keep the grill firmly closed when not in use or when stored so nothing can get lost or damaged
  • Anti-Slip Feet – 4 anti-slip feet help keep the grill in place on its surface to minimise the risk of accidents
  • 2 x 3kW Stainless Steel Burners – Gives plenty of power for outdoor cooking
  • Deep Drip Tray With Windguards – Designed to help protect the burners and keep the flame going
  • Individually Controlled Burner Valves – Regualates burner power
  • Built In Piezo Ignition – Easy to light, no matches required
  • Integrated PVC Hose With Auto Shut Off And Hose Tidy Storage – Built in gas safety keeps it compact
  • Corner Guards – Gives the cooker added protection
  • Uses EN417 Gas Cartridges – A mix of Butane and Propane makes this ideal for all temperatures
  • Estimated Burn Time At Maximum Flame Level With 450g Gas Canister – 120 Mins
Specifications
  • Weight – 4.35kg
  • Height – 10.0cm
  • Width – 33.5cm
  • Length – 47.0cm
  • Packed Dimensions – L59.5 x H14.5 x W34.5cm
ACVMAGMA0000001
Vango
Be the first to review “Vango Magma Gas Double Camping Cooker”
