VW California
Caravan
Drive-Away Awnings
Tents
Vango Nitestar Alpha 150 Sleeping Bag – Lagoon
£22.99 Inc VAT
Only 2 left in stock
Found this item cheaper?
The Vango Nitestar Alpha 150 Sleeping Bag is new for 202. The Nitestar Alpha 150 is a new addition to the award-winning Nitestar collection. With Vango’s Alpha insulation, combining excellent warmth properties with much-improved compressibility, it is lighter than ever before. Double-layer construction reduces cold spots, for a comfortable sleep wherever you go. Perfect for youth groups or your spring and summer adventures.
  • Alpha Insulation – Lightweight and extra warm, Alpha has a great loft while compressing to a small pack size
  • Polair® Diamond Shell – Diamond embossed Polair polyester for a strong, lightweight shell
  • Warmer Weather Design – A NEW single layer construction allows for a lighter, cooler and more compact design for warmer weather trekking
  • 100% Polyester 190T Slightly Brushed – A soft to touch microfibre lining fabric that is wonderfully cosy, snug and breathable
  • Two-Way Auto-Lock Zip – Seals in warmth and provides adjustable ventilation. Auto-lock prevents the bag from opening during the night and can be accessed from inside the bag
  • Mummy-Shaped Sleeping Bag – Tapers from the shoulders to the foot. Reduces packsize and increases thermal efficiency
  • Grab Loops – To aid zip movement. Hold loop when moving zip
  • Zip Guard with Anti-Catch Piping – Helps to prevent the zip from snagging on the lining, allowing easy opening and closing
  • Woven Zip Puller – Allows quick and easy operation of the zip
  • Hanging Loops – Allows you to easily hang your bag for quick and easy drying
  • Horizontal Stitching – Evenly spaced to hold insulation in place and ensure even distribution throughout
  • 3D hood with Drawcord Closure and Shaped Sides – Prevents heat loss from the head whilst the shaped sides provide additional comfort. The convenient drawcord closure provides maximum adjustment
  • Insulated Adjustable Shoulder Baffle – Retains heat within the sleeping bag
  • 4-Strap Compression Stuffsack – Minimises pack size for easy transportation
  • Insulated Zip Baffle – Retains heat within the sleeping bag and reduces cold spots
  • Internal Pocket – Provides convenient storage for small items
  • Temperature Ratings Independently Measured – In accordance with EN 13537:2002. Extensively tested to meet accurate temperature rating standards
Specification
  • Weight: 1.3kg
  • Packsize: 26.0 x ø20.0cm
  • Comfort: 8°
  • Fill Type: Insulite Alpha
  • Limit: 4°
  • Extreme: -10°
  • Suggested Usage Min: 4°
  • Suggested Usage Max: 20°
  • Ext Chest Width: 85cm
  • Int Chest Width: 83cm
  • Max User Height: 190cm
  • Int Foot Width: 48cm
  • Int Length: 205cm
  • Shape: Mummy
  • Performance: 1 Season
  • Zip Side: Left
  • Tog: 10.0
SBPNITESTL10111
Vango
Be the first to review “Vango Nitestar Alpha 150 Sleeping Bag – Lagoon”
£22.99 Inc VAT
