Vango Scran Medium Griddle Cooking Plate
£32.99 Inc VAT
Out of stock
Email Me When Back in Stock
No pans needed with the Vango Scran Griddle Range! The non-stick cooking plate has the option of a flat or ribbed surface, providing a healthier cooking style and is simple to clean. The adjustable thermostat lets you set temperatures to your desired heat and the heat resistant handles make it easier to move around.
  • 2.5m cable with UK plug – Extra long cable provides flexibility for cooking
  • Power: 1500 Watts – Allows for efficient cooking
  • Flat or ribbed non-stick grill plate option – Healthy cooking options and easy to clean
  • Adjustable 5 setting thermostat with light indicator – Control the temperature whilst cooking (80-240oC)
  • Heat resistant handes – for added protection
  • Leg Height Adjuster – allows unwanted grease to easily drain away from food
Specifacation
  • Weight:2kg
  • Packsize: L64 x H13.1 x W29.5cm
ACQSCRAN B05TG9
Weight 2 kg
Dimensions 42 × 12 × 31 cm
Vango
Be the first to review “Vango Scran Medium Griddle Cooking Plate”
You may also like…
  • Vango Tumblers 450ml – Pack of Four
    Original price was: £9.99.Current price is: £3.99. Inc VAT
£32.99 Inc VAT
