VW California
Caravan
Drive-Away Awnings
Tents
Vango Vista Cinema Screen
£33.95 Inc VAT
Only 2 left in stock
Found this item cheaper?
Our new Vango Vista Cinema Screen is a game changer compared to your usual camping activities. Its compact size makes it ideal for taking on holiday and it easily attaches to Vango’s SkyTrack® tents or using the toggled bedroom connectors inside your tent. Its unique 2-in-1 design gives you flexibility to use as half or full screen depending on the size of your tent and its 130 degree viewing angle gives everyone a bright image from almost every seating angle. You can expand the seating area for viewing by positioning the projector behind the screen when its at full size so all your family and friends can gather round to watch a movie.
ACSVISTA0000001
  • 2-in-1 Design: Full Size and Half Size Screen – Maximum flexbility for use in every tent size. Large 120 x 160cm full size screen and compact 80 x 120cm half size screen
  • 4 Point Adjustable Webbing Anchors – Excellent tension on screen to iron out wrinkles and give maximum stability
  • Detachable Webbing Anchors – Easy to fold-up and move around
  • Flexible Polyester Screen – Crease-resistant, even after folding
  • Rear-Projection Ready – Position the projector behind the screen (i.e. in bedroom) for a larger seating area. Only applicable in full size
  • 0.9 Gain – Absorbs some ambient light whilst still reflecting the light from the projector. Gives a good image, even in daylight
  • 130 Degree Viewing Angle – Bright image from almost every seating position
Specifications
  • L12.0 x H25.0 x W7.0cm
  • 0.55kg
Vango
Be the first to review “Vango Vista Cinema Screen”
£33.95 Inc VAT
