VCDS VAG-COM VW Audi Seat Skoda Diagnostic Services Chesterfield
Price range: £25.00 through £40.00 Inc VAT
VCDS VAG-COM VW Audi Seat Skoda Diagnostic Services Chesterfield. On-site diagnostics and adaptations for VAG group vehicles – from 1996 – to the present (including most models that require SFD codes)? using the very latest Genuine VCDS HEX-V2/NET Hardware and Software.
  • Full fault code scan analysis and printout.
  • Removal of Airbag lights. (Airbag lights will return if the vehicle’s airbags are faulty, blown or removed)
  • Resetting service interval.
  • Adaptations,/ Coding  such as folding mirrors, Led bulb coding, start-stop, dial swipes courtesy lighting, seatbelt chimes etc, rear speaker and fader operation (VW T6.1) this is different by vehicle please enquire.
  • Monitoring and data logging of certain modules of the vehicle to understand more detailed faults.
  • Enabling of aftermarket accessories such as Steering wheels, parking sensors, cruise control,reversing cameras, LED light upgrades, towbar accessories etc.
  • New Stop Start Battery Coding (when replacing a battery on a stop- start vehicle – the ECU needs coding to recognise  and charge the new battery correctly)
Please email us with the details of your vehicle and what service you require.
Fault code scan, print or email – then removal (Including Airbags) £40 – Some codes may return if vehicle equipment is faulty, (Airbag lights will return if the vehicle’s airbags are faulty, blown or removed)
Aftermarket Accessories – From £40
Adaptations £25 for the first adaption then £10 each after this.
Please email – [email protected] with any inquiries and to book an appointment.
Service
Fault Code Scan / Removal, Aftermarket Accessories Setup, Adaptions (Each)
Be the first to review “VCDS VAG-COM VW Audi Seat Skoda Diagnostic Services Chesterfield”
Subtotal: £197.99
View basketCheckout
