Vango Versos Groundsheet Protector
The Vango Versos is an ideal-sized air awning, perfect for storing tables and even sleeping in.
The groundsheet protector offers a range of advantages and is an important addition to your awning set-up, offering a cut-to-fit footprint and assisting in lengthening the lifetime of the Versos.
Coming as 4 separate parts, the Versos groundsheet protector is made up of the following:
- 1 part for the main awning living area.
- 1 part for the tunnel.
- 1 part for the bedroom annex.
- 1 part for the front canopy.
There are many benefits of using a groundsheet protector, not only does it protect the material on your awning from stones, thorns & other hazards, is easy to wipe down and clean, and also prevents the need to clean the awning every time it is used.
When pitching the awning, the groundsheet protector can be used to mark out the intended pitching position. It can be easily moved to the desired pitching position before the awning is erected, and, equally, when the awning is being deflated and packed away it allows the awning to remain clean and protected from the dirt and stones underneath.
Included is a neat carry bag, simply fold the groundsheet protector and pop it into the carry bag for easy carrying and storage, measuring at just: 59cm x 13cm x 12cm and 2.43kg.
GPUGP0150000001
