Sale!
Vision Plus Quick Release Black LCD TV Vesa Wall Bracket
Original price was: £18.99.£4.99Current price is: £4.99. Inc VAT
Out of stock
Email Me When Back in Stock
Vision Plus Quick Release Black LCD TV Vesa Wall Bracket. Two rigid plastic plates designed to simply slide together between your TV wall mounting bracket and your TV
- First plate fixes to the VESA fixing on your LCD TV
- Second plate fixes to your wall mount bracket
- Two plates simply slide together and ‘Click’
- To remove TV press tab and slide out
- Can also be used as a wall bracket
- For use with all VESA brackets 75mm and 100mm
- Slim fit-only 15mm thin
- For LCD TV’s up to 23″
- Max load 15kg
- Colour: Black
Check screw lengths before attaching to the TV, beware that they are not too long because they could damage the electronics inside the TV.
“CLICK” it’s on, “CLICK” it’s off… It couldn’t be simpler!
| Weight | 0.85 kg |
| Dimensions | 24 × 18 × 9 cm |
You may also like…
