New and in stock now!
If you’re after something a little different for your California – Here we have something new & exciting a set of 2 packing cubes & a hand-made duffle bag custom to fit for the VW California’s Wardrobe area made in the UK.
The smaller packing cube fits in the very bottom of the California’s Wardrobe (if you do not have the factory fitted safe) and the larger one fits in the wardrobe above this.
There are made in a faux leather and a selection of front-finish materials. They come with a large zipped-up side for easy access.
Set includes 1 x Small cube = 35cm long, 12cm wide & 30cm high and 1 x Large cube = 50cm long, 18cm wide & 36cm high
Duffle bag = 42xm long, 26cm wide & 19cm high
More designs coming soon.
Please be aware as the review states below – the set is only for the 2 packing cubes and the duffle bag is available on its own.
| Type | Small Packing Cube & Large Packing Cube Set, Duffle Bag |
Reviews (1)
1 review for VW California Packing Cubes & Bag
Price range: £49.99 through £89.99 Inc VAT
Will Shaw (verified owner) –
The two cubes are well made and look nice.
The way the website and my invoice describes the cubes (plural) and bag (I assume the duffel bag) as what you will receive can be misconstrued. I actually only received the two cubes when I thought I would get all 3 items as show in the pictures. My novice states cubes and a bag. A bit misleading and the website shop should be adjusted to point out more clearly you will only receive EITHER two cubes OR the bag. Too expensive to send back. So had to keep the two cubes.
