Wastemaster 38L Waste Water Carrier – Beige
£54.99 Inc VAT
Only 2 left in stock
Found this item cheaper?Wastemaster 38L Waste Water Carrier – Beige
The Wastemaster allows for convenient disposal rather than allowing wastewater to flow around your pitch and onto the site.
Due to the high number chemicals contained in grey water by disposing of your wastewater responsibly, it also helps project environment and wildlife. The Wastemaster has a capacity of 38 litres allowing it to easily under your caravan. It is also fitted with three filler caps which allow the Wastemaster to be filled up to its full capacity even when on uneven ground. The Wastemaster features a ledge on the front of the container which is designed to hold a caravan toilet cassette. This can then be secured by fastening it to the Wastemaster using luggage elastics supplied with the product allowing the Wastemaster to be a dual purpose waste disposal unit.
We are very confident of the quality of our product we are offering all FL Hitchman Wastemasters sold after 2016 now come with a FREE 10-year Container Guarantee. Product registration must be completed at the time of purchase – Click here for full Terms and Conditions.
* The Wastemaster is not sold with a toilet cassette. *
What makes our product unique
38 litre capacity.
The unique shape gives good balance.
Wheels and axle easily removed for cleaning and storage.
Take waste water and toilet cassette to disposal.
Wide wheels to spread load on soft ground.
Carry platform for toilet cassette etc… luggage elastics included.
Dimentions: 355mm x 1000mm x 160mm
Product Weight – 4.5kg approximately
Weight | 0.75 kg |
Dimensions | 32 × 17 × 37 cm |
