Wind Out Awning Rain Seal Fiamma – Thule
This Fiamma Rain Guard Seal Kit is a convenient rubber guard to seal the space between the awning and the vehicle wall to prevent infiltration.
Suitable for-
Fiamma F35, Fiamma F45S
Thule 5102 4200/4900 Awnings.
This rain guard has an adhesive strip which is applied to the rear box of the awning and can easily be fitted without the need to remove the awning.
The seal comes in a 3.0m length to fit either a SWB or LWB minivan (can be cut to size). The total strip size is approximately 11cm whereas the strip which covers the gap between the awning case and vehicle is approx 8cm. You will need to make some allowance for the curvature of the strip, however it should cover gaps up to of 6cm – 6.5cm depending on the position of the rain guard seal on the awning.
Recommended for use with an awning fitted to:
- Standard roof Vauxhall Vivaro, Renault Trafic & Nissan Primastar
- VW Transporter T5 fitted with Transporter or Multivan Kit
- VW T5 Transporter with Reimo or Brandrup kit
- VW T4 using kit 98655-292
- Ford Transit using fitting kit Kit Van 98655-017
- Ford Transit Nugget
- For wind out awnings click here
![pre-order-cubo-breeze-v2-campervan-awning-olpro__34240.1721396565[1]](https://vwcaliforniaclub.com/shop/wp-content/uploads/2024/10/pre-order-cubo-breeze-v2-campervan-awning-olpro__34240.17213965651.png)
