Sale!
Zonesleep Downstairs Mattress Topper for the VW Rib Bed 112cmZonesleep Downstairs Mattress Topper for the VW California SE/Ocean
Zonesleep Ultra Downstairs Mattress Topper for the VW Rib Bed 112cm VW T5 T6 T6.1
Original price was: £399.99.Current price is: £349.99. Inc VAT
Only 2 left in stock
Please be aware the pictures are of the standard Zonesleep Topper, not the much thicker Ultra variant – more pictures to follow soon.
Zonesleep® mattress toppers are made up of three ‘zones’ of two dimensional knitted textiles and one hi tech layer of breathable coolmax…….(NO FOAM!) The bottom layer of our mattress toppers contain slightly stronger yarn to provide support for posture. Layer two is soft and designed to give provide comfort. The top layer of Coolmax® (a high tech fabric which forms a unique moisture management system for improved air circulation and reduced humidity) creates a pleasant micro-climate while you sleep, keeping our mattress toppers cool & dry.
he Zonesleep Ultra Mattress has been designed specifically to add extra comfort to the RIB 112cm Bed – typicall found in a VW T5 T6 T6.1
It is designed to provide a whole new level of comfort for sleeping downstairs and is the only product you need for a great night’s sleep.
The Ultra mattress comprises of 3 sections, all using special 3D Spacer Mesh Fabric. The upper layer is like the normal Zonesleep Topper with the new 300gm ‘Tencel’ surface layer and a new quilting pattern. It just zips together with a bottom 10mm layer and inside is a separate 20mm thick removable 3D spacer fabric pad.
Washing
One of the great things about the Zonesleep toppers and mattresses is they can be washed ! The whole Ultra mattress can simply be taken apart to allow you to wash it. The individual parts will
probably not fit into a normal sized domestic washing machine however you can wash it by hand in the bath and then allow to drip dry or you can use a commercial laundry which will have bigger washers and dryers
Model: VW Rib Bed
Size: 112 x 186cm x 5cm
Note: We are unable to ship this product to Switzerland or Norway
The Video Below is of the California variant of this Mattress, but the RIB variant is identical apart from the footprint o the item.
Weight 6.5 kg
Dimensions 61 × 80 × 27 cm
Zonesleep
Using innovative 3D 'Spacer-fabrics', 'Zonesleep' products offer the latest in sleep comfort. Provide you with a new way to sleep.
Be the first to review “Zonesleep Ultra Downstairs Mattress Topper for the VW Rib Bed 112cm VW T5 T6 T6.1”
You may also like…
