From what I can ascertain -
Fuse S65 is an 80A fuse that protects the 2nd Battery.
Fuse S339 is a 50A fuse that protects the Additional (3rd) Battery.
The camping equipment fuse panel (charging unit (S60 30A), electric roof (S67 30A), interior lights (S47 10A), cool box (S340 10A), water pump (S341 5A) & display unit (S63 5A)) is supplied via the 80A fuse S65 which appears to be located under the seat.
It may be quite a large fuse which sits on it's own attached to the relay carrier plate.
If you've blown this fuse then something hefty has happened. If it were me I would remove all of the consumer fuses I mentioned above before replacing the large S65 80A one. Then one at a time replace the others and by process of elimination you should find your problem.
