3A, 6A or 10A
N
nickandemma
Leigh on Sea
T5 SE 140
I know nothing about electricity and have to chose which plot to book on a site in France - they are offering 3A, 6A or 10A. Please could someone tell me which to use, we'll only be boiling the odd travel kettle, and charging the ipad/phones. :thanks
Just choose the 10 amp then you are covered :thumb
OR
If your only there for a few days.....don't have hook up and save money......battery's will last about 4/5 days
Power (Watts) = Volts * Amps
So + 230V
3A = 690 Watts
6A = 1380 Watts
10A= 2300 Watts
iPad / iPhone charger is <12W
Laptop charger is around 100W
A travel kettle will be anywhere from 650-3000W (The higher it is, the faster it will boil the same amount of water)
Hope this helps,
Simon
Also bear in mind that the battery charger will be using power as well if you are on hookup. The fridge will be running from the batteries, so they'll be charging a lot of the time.
Not much, but enough to think about if you are close to the limit of the supply with your other devices.
I have had the experience of asking the site warden to reset the tripped electric on the hook up bollard :oops: go for the higher one
Ron.
We've been fine with 6A when abroad but as the others say 10A is your safest bet if available
Sent from my GT-I9505 using Tapatalk
theoldmancunian
theoldmancunian
theoldmancunian
simplybikes
jts46
jts46
