Air Con Query
D
Davidag
Southampton
T5 SE 180
Hi All,
Have a air con problem on my 2009 T5 California (Auto Diesel), seems to work fine until the engine temp gets around the mid temp range and the air con starts to shut down? Has had a new compressor/radiator fitted.
Sounds like if it’s working when cold and not as the engine warms up you potentially have a blockage in the system. Can I ask why the a/c compressor was replaced and also was your a/c system flushed when the compressor was replaced. I feel you may have a blocked TXV unit.
