Auberg-ine
Is it an office? Is it a lounge? Is it a camper?
... and so in the middle of the night, I woke up, drilled a hole in the top of the window frame, cut both ribbons, cut the tops of the suction cups, and fixed these on the lower part of the window frame
This means I can no longer use it outside. But I already have an outdoors bar counter (#291), and I don't trust so much suction cups to charge onto; not everything lands as well as cats.
I know, it's just an extra gadget, but I see myself using it quite a lot. The Cali table is so quickly filled with papers, dishes,...
And again, while driving long distances, the person on the right side of the bench needs more comfort to put his things as well.
So this extra frame can be put in a horizontal or vertical position (while the door can still open), just by clipping it into the plastic tops (I cut a slot into them to reach the existing perforation), and moving the rope fixation points to the middle. I still found two little rubber sealing rings to avoid rattling against the window. The 'cat's carpet' has velcro, which can easily be removed and folded away, keeping a free view.
Edit: instead of moving these fixations to the lower corner and keeping them in position with a safety pin, in order to keep the frame vertical, it turned out to be easier to just flip the frame, so that the fixation (and so also the canvas does not need to be removed:
.This means I can no longer use it outside. But I already have an outdoors bar counter (#291), and I don't trust so much suction cups to charge onto; not everything lands as well as cats.
