I have BFG 225/65/17 at the moment if you intend doing loads of off road then great, but fuel consumption takes a big whack (5mpg).I have the same issue. Bought recently a T6.1 Beach Camper 150 Hp 4Motion additionally 30mm lifted. My California (with Standard tyres 215/60 R 17 C 109/107 T) is not delivered yet. In advance I want to buy all terrain tyres including rims. The only thing what my dealer said is that I only can use two types:
Which all terrain tyres are recommended comparing e.g. BFGOODRICH®TRAIL-TERRAIN T/A®?
- 215 / 60 C 17“
- 215 / 60 R 17“
Do you recommend a all terrain spare tyre in general too or is usage of standard spare tyre possible / acceptable?
Please post photos after Seikel have finished.Many thanks for all replies. Much appreciated.
Related to one hint above here further information to Seikel:
Seikel will lift my California.
Now that you've had for awhile, what are the pros and cons?Fitted a few months ago to my 6.1 Coast; 235/55R 18 Falken Wildpeak AT3 on Wolfrace Explore. Excellent ride, no real increase in noise, slight difference in mpg.
Looks really good. Is this a standard ride height beach camper. .Im looking at options for mine and its a bit overwhelming .. Ideally I want to do the wheels then when funds allow possibly do the suspensionFitted a few months ago to my 6.1 Coast; 235/55R 18 Falken Wildpeak AT3 on Wolfrace Explore. Excellent ride, no real increase in noise, slight difference in mpg.
Looks good, I wonder if I can fit those to my original VW 18 black wheels, normally 255/45/18 ???Fitted a few months ago to my 6.1 Coast; 235/55R 18 Falken Wildpeak AT3 on Wolfrace Explore. Excellent ride, no real increase in noise, slight difference in mpg.
I'd love to see a picture of these on the van Blue. (if you have such a picture). No way of getting non-standard sizes on my van here unless i change them every year for the MOT (control), so i'm interested in getting a set up like the one you show here. Unclear if i can life my van up 30mm either. I'm struggling to find out what the process is for doing so.I have BFG 225/65/17 at the moment if you intend doing loads of off road then great, but fuel consumption takes a big whack (5mpg).
I’ve got a set of Michelin latitude cross 235/55/17 for my next fuel rated C compared to F for BFG.
Still look pretty chunkyView attachment 87837Side by side BFG and Michelin latitude crossView attachment 87838
That's fabulous, thanks. Looks great. I think I'll go for the same!View attachment 103141
Hope that helps
They do them 215/60/17 too, if you want higher side walls.That's fabulous, thanks. Looks great. I think I'll go for the same!
Like the look of this wheel / tyre combo but find all the jargon a bit confusing...when I look at the rims they are stated as being 8J whereas the stock wheels on my Ocean are 7J (tyres are 235/55/17). I can see that an 8J is used for 18" rims - so my longwinded question - are 8J's with a 17" rim ok? Do you need to specify an offset?I have BFG 225/65/17 at the moment if you intend doing loads of off road then great, but fuel consumption takes a big whack (5mpg).
I’ve sold van now, but done 7000miles on them before I did with no issues.Like the look of this wheel / tyre combo but find all the jargon a bit confusing...when I look at the rims they are stated as being 8J whereas the stock wheels on my Ocean are 7J (tyres are 235/55/17). I can see that an 8J is used for 18" rims - so my longwinded question - are 8J's with a 17" rim ok? Do you need to specify an offset?
How are yours after 18 months use?
I think you have confused rim sizes with tyre sizes. You can buy 8J 17 inch rims but for the transporter family it’s 17 inch 7J or 18 inch 8J and corresponding wider or narrower tyres with lower or higher sidewalls to achieve a similar diameter.Like the look of this wheel / tyre combo but find all the jargon a bit confusing...when I look at the rims they are stated as being 8J whereas the stock wheels on my Ocean are 7J (tyres are 235/55/17). I can see that an 8J is used for 18" rims - so my longwinded question - are 8J's with a 17" rim ok? Do you need to specify an offset?
