welshwestie
- Messages
- 105
Hello all. My original Philips PE 2169/01 has been replaced with a Victron Blue Smart IP 67 mains charger. I opted for the 12/25 SI model so that I could continue to have the prong appear in the E 153 display. Basically insert the SI cable into the six pin block, green wire. The green wire is connected to the E 153.
Reason for replacing the Philips is that I am moving to Lifepo4, and the Philips is a) not intelligent b) vented another Wima film capacitor, for the second time. Both times EHU was plugged in, fridge on, and sun shining on the side of the van. As Corporal Jones would say, the Wima "dont like it up em!!!" I will replace the capacitor, this time with a more modern option, and stick it on the shelf.
The only version of the 12/25 si I could find comes with a euro plug, so I needed to purchase a IEC C14 adapater to Euro female. I wanted to retain the factory 'kettle lead' and not void the Victron warranty by removing the original Euro plug.
In order for the SI cable to remain in the 6 pin connector, I crimped a molex male pin and this was a good tight fit.
I thought that the Victron was a better option than the Fraron.
