thesquirrelpatrol
- Messages
- 164
Speccing up our new GC600 and wondered if anyone with these options could advise whether they are good/bad ideas?
I did ask this question but the Dealer has confirmed that with those options we are still ok to stay at 3.5tNice set of options, you don't look to have left anything off that I would want.
Are you trying to stay under 3.5tnnes? if so I don't think you can have the extra bed + towbar + awning and stay within the weight limit.
Looks good, not too dissimilar to mine!View attachment 95658
Here’s the options list as things stand
| Candy White/Mojave Beige | 9198 |
| LED headlights | 8IT |
| Lights & Vison Pack B | ZLS |
| Blind spot monitor | 7Y8 |
| Driver assistance Pack D w/side protection & Park Assist | 9X1 |
| Rear View Camera | KA1 |
| Wing Mirrors - Heated & Power Folding | 6XP |
| Ambient Lighting | YYB |
| Step Illumination | 9N2 |
| Awning White | YBA |
| Overcab Bed | YBC |
| Solar collector on the roof, 104W | YEI |
| Toilet Vent SOG System | YDS |
| Inductive Charging Cradle | YED |
| Mudflaps F&R | 6N2 |
| Chrome Pack | ZL6 |
| Heating system for water and interior powered by mains electricity or diesel | YHC |
| Auxilliary heater - with programmable parking heater and remote control | 7VL |
Ye so turns out when the dealer went to place the order that with these options it is over 3.5t. Options are that we remove 2 out of the 4 big options - diesel heater/solar/awning/towbar or most of the smaller options and one of the big ones. The other option is I sit my cat c1 licence. If rated over 3.5t should I be worried about resale as this presumably limits how many people are able to drive it?Nice set of options, you don't look to have left anything off that I would want.
Hello Eberhar,Hello,
Heating, solar panel, weight of the camper etc. all these things are going through my mind at the moment (even if I already have a GC 600) as well.
May I share my thoughts about this (and I am not even near with finding a good solution).
From heating point of few I don't believe there is a difference between diesel or gas. As mentioned before I have read on different places that the diesel heater need a bit more electricity.
I believe the main difference is the logistics of replacing "burning material". Obviously there is no real issue with a diesel heater. Gas is a different beast. If you use standard gas cylinders you might (no you will) have problems to replace them abroad. Each country has their own standards. I changed to LPG which helps, but still. We just came back from a 3,5 week trip in Europe. I kept the heater on to have warm water and (even it kept to switch off) I used about 1 1/2 bottles. More than I expected. In other words - if I could configure a camper it would be always with diesel heater.
Our GC 600 came with the solar panel. Even thought it is a small panel it provided enough power to charge the battery. So even the standard GC 600 is worth to get (at least if the weather is good).
Everybody is talking about "autarky". Yes the battery is an important factor, but even with the standard setup and a standard VW solar panel it always lasted from early afternoon to next late morning. It could be a wee bit more, but hey. The key issue for standing autark is the toilet casette. I say it needs to be emptied at least on the third day if two people use it.
Weight is a big issue. To configure the van that is under 3.5 t is only half the battle. For instance. I prepared my GC for traveling. The weight of the van was 3,240 kg. Now I have to add our weight, cloth and food and I believe we came over the famous 3.5 t.
During our roadtrip through France, Spain, Andorra and Portugal (5224 km) we drove dozens and dozens of times on roads forbidden for vehicles over 3.5 t. Because of this a change over 3.5 t would never be on my list.
Best of luck with your plans. I hope you won't feel like me, the more I think about it the more complicated it gets.
Best of luck,
Eberhard
Hello Eberhar,
I have had a panel fitted earlier this year and certainly if enough bright light, it appears to keep my batteries topped up. On cloudy days and into the winter however, it’ll price to be less effective with shorter darker dayswe mostly do wild camping so self sufficiency is key. Our current GC600 has the gas heating system and we inadvertently ran out of gas once so I was keen to avoid that ever happening again plus it means only carrying gas for cooking saving on space/weight.
We have had issues with battery charging off the engine in our current van so I was considering speccing the solar for this one but its an expensive option and I was hoping someone who has solar fitted could let me know if it actually works in real life to keep the battery charged up better than trying to keep it topped up off the engine intermittently.
You can retrofit after, but don’t understand the logic. If you can’t fit at point of order due to weight, but you will fit it after. Surely still a weight concern?Got our order placed yesterday. Had to delete the awning and change the towbar to just the prep to get under the 3.5t. Can get rest of towbar installed as retrofit.
Van can only be registered with 4 seats if there is sufficient payload for four passengers + an EU prescribed amount of luggage each.You can retrofit after, but don’t understand the logic. If you can’t fit at point of order due to weight, but you will fit it after. Surely still a weight concern?
Yeah I get that Andy. Just not sure I wouldVan can only be registered with 4 seats if there is sufficient payload for four passengers + an EU prescribed amount of luggage each.
Hence Ireland being able to register GC680 at 3.5 tonne but only as 2 seaters with no rear seatbelts, same for the 4 motion Ocean not being available with the extra seat.
Any thing that is done after registration is up to the owner just need to be aware that it is eating into payload.
Very thin profile and weighs very littleYou can retrofit after, but don’t understand the logic. If you can’t fit at point of order due to weight, but you will fit it after. Surely still a weight concern?
Talking about towbars on a Grand California.Very thin profile and weighs very little
Our experience with CG 600 heating:
I bought 2 Alugas lightweight alu bottles, see www.alugas.de and the 3 different connecting pieces used in Europe. Empty, each bottle weights 5,5 kg. They have a security system that block the inlet at 80%. I fill them at gas stations with LPG. Full with 20l they weight 15,5 kg each. We are home from a 8 weeks trip trough Switzerland and France. We only used 7,6 litres from one single bottle. Obviously we only used gas for a little heating in the morning and for light cooking. We don’t heat the boiler, cold water is good for the skin.
The app “myLPG.eu“ gives you the list of LPG stations in Europe.
enjoy,
Max
