Barryjm
- Messages
- 231
- Location
- Forest of Dean
My auxillary heater seems to have stopped working, it started up blew out cold air for a while then stopped and now no longer starts!
The control panel works OK, apart from the display which is breaking up and the control knob which I have just superglued together! The heating button goes yellow and all looks to be OK but nothing happens with the heater at all, not a single noise!
I have checked both fuses under the passenger seat; the batteries have a good charge and I have even plugged in the mains. There is plenty of fuel in the tank.
I have no idea if my van has the earth shunt fix, I have never had a problem before and I have had the van almost 4 years. I did get some flickering of lights when the heater worked?!
Everything else still works.
I have checked the heater in the back under the cover by the rear door and there does not seem to be any power to any of the wires. Does anyone have a wiring diagram for the Cali? I was just poking around trying to pick up 12volts.
Are there any other fuses I should be checking?
I really don't want to have to take this to VW?! :crazy
