Awning winder handle retaining clips
Spartan
Spartan
(not human)
Up North
T5 SE 180
The forum shop usefully sells spares (albeit at rather expensive, genuine VW prices) and there are two different versions to choose from.
The later version of the clip for 2011+ (2012MY) vehicles is more substantial than the earlier one and the new design has an increased 'stand-off' from the drawer sides that enables drawer-side mat, carpet, etc. to be fitted without affecting secure retention of the winder handle - which is why I purchased a set.
Easy enough to retrofit to earlier models - drawer unit just lifts out after undoing two small screws from inside the drawer bottom; remove plastic drawer trim (a self-tapping screw helps extract the trim clips); simply pull out the old winder handle retaining clips and use a step-drill to increase the existing holes until just big enough to accept the compressed, new clips (12mm hole); add a short horizontal notch to each hole at 3 & 9 o'clock positions, using a needle file/small drill, to fully accept the new clip (that also features an anti-spin feature that the old ones did not).
