b100b1b
G
gandalfthegrey
England
T5 Beach
Hello all.
My airbag fault light came on and it appears to be a resistance issue under the drivers seat.
I've had a look and it appears that a connector is not connected.
Could this be the issue? If so where does it go? If not what else can I try.
I've no idea what is going on with the spacing apologies can't seem to fix it.
Here's a picture showing connected wire and disconnected wire.
Yes. That is the likely fault. But, I think, even after plugging back together you will need to reset your warning airbag icon via a dealer - unless you have Carista or another fault resetting device.
