![Zebra](/data/avatars/m/14/14897.jpg?1508305790)
Zebra
That’s pretty good I was quoted £92 just to supply the top bit sprayed from The garage in Aberdeen. So I’d definitely get your garage to do it.Yes unbelievably !!
However for future reference if you slide a wide trim tool in behind the top of the mirror it’ll pop off fairly easily and then there are two wires for the heating element that disconnect easily. Once the Mirror is off you’ll see the two screw heads you were looking for Tx10 if I remember correctly. After that removing the top and bottom bits is fairly easy but the clips are notoriously fragile so another good reason to let the garage do it.
