sidepod
- Messages
- 6,980
- Vehicle
- T4 PopTop
Perhaps as the HD bars have a different section they reduce the slump in the suspension and thus make the vehicle sit slightly higher?
Please go and study how an anti roll bar works. !!
It is phisicslly impossible for it to apply any load either positive or negative to the springs. In other words it can't affect ride height.
In a static condition it is completely unloaded.
It is attached, via bushes, to the chassis but free to move around an axis across the vehicle. Think about this - this makes it impossible to load the suspension.
Outboard, it is attached, via drop links, to the wishbones of the suspension.
In a straight ahead condition under bump loading, both wheels will move upwards together. The AR bar will simply rotate in its bushes across the vehicle, unloaded.
In a cornering condition one wheel will load up more than the other. This condition causes a tortional load to be applied to the AR bar. This load causes the unloaded wheel (inside of the corner) to follow the loaded one. Gravity takes over and counteracts the roll in the vehicle.
As far as a VW suspension package is concerned, perhaps the heavy duty bar is fitted in conjunction with modified springs. The latter causing the ride height change.
A stiffer AR bar will also affect understeer.
