Changing varta 92 ah battery for a 150ah lithium in g c 600
I don’t just the panels, when it needs speed you can charge to 100% from a normal 220v socket in about an hour, or from a 12v socket while I’m driving all 3 options are better than relying on a single 175w solar panel that VW offer from the factory - It works for me anyway and the cost was about £1,200 all in !
Clearly works for you..but relying on charging from a 240v outlet rather defeats the point of an off grid solution for us
The cost of a replacement 150 Ahr lithium battery, and a 50A dcdc charger plus installation around 1500 quid...so not much different. Currently we are using in France and with fridge on continuously plus general living electricity draw we have never had the battery below 60% charge. Solar from the vw panels provides reasonable top up and drives between stops dumps 50A (600w)/hour driving. Not hooked up to a 240 v supply for about a week now.
The panel shows 100% battery SoC at all times !...and despite the dire warnings of electrical shutdown when 30plus amps of draw has occured (through the KFG)...this hasn't happened to us as yet
I concur. It's a no brainer.
This one works in the dark!
Yes at present although I do have a 15 amp victron lithium charger in the cupboard ready to fit. So far it seems unnecessary. I'm still at the testing stage.
Hi,
Did you get fitting the Victron charger? I had a look at the Dometic charger fitted as standard under the passenger seat and have noted an extra wire, a thinner gauge, blue wire going into a connector plug, which branches into four wires? Do you know what the blue wire is for?
Many thanks.
Victron charger fitted and charging the Lithium via a Wago in the technical cupboard
(+ 7.5amps).
With the under seat charger, fuse six removed (supply to leisure battery), when on hook up it still charges engine battery and low amps.
Looks like you also have an inverter - the 3 wire connector -blue/black/red. That’s not a UK option so can’t help with that unfortunately. The 4 wire connector to the EHU charger is leisure battery/starter battery/-ve & signal wire for KFG which outputs 12Vdc when 230Vac is present.
J'ai ajouté une batterie LiFePO4 de 100 Ah dans le placard arrière avec un convertisseur CC-CC de 30 A connecté à l'arrière de l'interrupteur d'isolement que j'ai remplacé par un interrupteur 1-2-off. Donc, essentiellement, la batterie AGM d'usine charge ma batterie au lithium. Les paramètres du CC-CC sont tels qu'il arrête la charge lorsque l'AGM tombe à 80 %. Tout est contrôlé via l'application Victron.
Cela signifie également que le solaire continue de charger la batterie AGM et que celle-ci charge à son tour le lithium lorsque le véhicule est stationné, et lorsque l'alternateur roule, il charge l'AGM qui à son tour charge le lithium.
J'ai cette configuration depuis presque un an maintenant et elle fonctionne bien. J'ai toujours sélectionné l'interrupteur d'isolement de la batterie sur le lithium, ce qui donne déjà une capacité utilisable bien plus importante que l'AGM.
Cette configuration fonctionne bien si vous n'avez pas besoin de 230 V « hors réseau », ce qui ne me dérange pas.
Bonjour Monsieur T, avez-vous des photos et des schémas de votre montage ?
Bien cordialement
Julien
