R
RachelD
I have a question:Hi, I have tried this myself, I have an eco tree lithium battery which I've used on a previous motorhome.
So .....
You can do it, however there are some things you need to be aware of ...
You can simply swap out the battery under the bonnet (Habitation) battery with the Lithium battery.
Everything will work, as with the AGM battery .....
EXCEPT FOR ..
The Battery charge indicator on the control panel will show the battery as being 'full' pretty much until it isn't, this is something that you can't change (without re-coding the vehicle software) which is not easy to do.
The lithium battery will ONLY charge when the 'fast charge' button is pressed on the dashboard.
The Lithium battery will drain very quickly (20+ amps) as soon as the engine is stopped after it has been on charge using the method above.
You MUST stop the engine, with off the ignition and then it will stop discharging.
I tried it for a few months and I've now re-fitted the original AGM battery as the lithium battery just created other problems which I felt weren't worth the benefits.
So, in short, yes, a direct replacement is possible if you're happy to put up with the issues above.
I've added a second battery in the rear cupboard by changing the battery isolator to a 1, 2 & 1+2 selector switch, it then increases the capacity by 100% so around 100ah which is fine for 2 nights off-grid, using fridge and lighting, TV, charging devices etc.
If you need more than this 'off-grid' time you can have a lithium system fitted which replaces the charging (DC-DC) MPPT if you have solar, and so on, but they come at quite a high premium.
Hope this is helpful to you in some way.
The GC seems to have a VSR for dealing with charging the leisure battery when driving, and separately a solar charge controller for the rest.
I have fitted a solar system to my T5.1 which is 240w solar to a lithium battery which is charge controlled by a CTEK d250se. The CTEK handles both split charge and solar and will charge the starter battery as well if the leisure battery is full.
It’s £250 and siting it/wiring it may be a challenge but theoretically it should avoid all the problems except the display issue. It has a control wire for the smart alternator issue as well.
This would eliminate/replace the votronic in the back and the split charge relay wherever that is
Have I missed anything before I start scratching my head about where to hide the CTEK and run the inevitable extra cables?
