Have you checked the fuses for the Control Panel?It’s a December 2016 2017 model year so sadly out of warranty
I’ve been told there is one 5amp one underneath the passenger seat, is there more than one ?Have you checked the fuses for the Control Panel?
Resources section. Fuse information mainly by @Loz
I believe so, according to @Loz Fuse Diagram of the fuses in the lower Dashboard.I’ve been told there is one 5amp one underneath the passenger seat, is there more than one ?
According to @Loz in his picture above, there are 2 fuses for the Control Panel on the Fuse Board where the Bottle Cooler is.Looked at 2 5A fuses one under passenger seat and one in main in main fuse board where bottle cooler is both look OK so not sure where else to look or what to try other than running up a huge bill at the VW dealer for a diagnostic check, surely a control panel shouldn't have gone in just 4 years, it was working before it went in for MPT but cant think that they would have plugged anything in to make it go wrong, so so bloody frustrating.
I checked the 3rd fuse down on the right as it suggested but can’t see where the other one is
As you mentioned the copy of the diagram is a fuzzy so not easy to work out
In the end I took it in to VW for a diagnostic check they have checked all the wiring and concluded it the actual control panel that is at fault and want a hefty £936 to replace and fit which seems madness, it take about 2 minutes to take it out and replace it basically plug and play, rather surprising for a vehicle that is only just 4 years old with just 15600 on the clock, I have asked if they can get a contribution from VW as the thing has been fully serviced too, crazy money for what is realistically a £60 bit of plastic
The Forum Shop can probably get a replacement that you can fit, or contactIn the end I took it in to VW for a diagnostic check they have checked all the wiring and concluded it the actual control panel that is at fault and want a hefty £936 to replace and fit which seems madness, it take about 2 minutes to take it out and replace it basically plug and play, rather surprising for a vehicle that is only just 4 years old with just 15600 on the clock, I have asked if they can get a contribution from VW as the thing has been fully serviced too, crazy money for what is realistically a £60 bit of plastic
