Where abouts was the corrosion for them to need to remove the roof.? When mine was done everything was done in situ.Roof was removed by VW 5000 miles ago, for front corrosion issue, and has hardly been used since. Complained and now dealer says they'll pay for the part if I pay labour costs..£850 + vat. Is this fair?
Takes 10 minutes to remove the Control Panel on a T5/6. You don't need to remove roof lining.They wanted nearly 500 just to remove the roof lining to access the panel. I feel ill!
What van have you got, as they normally just pop out on T6 or olderThey wanted nearly 500 just to remove the roof lining to access the panel. I feel ill!
Corrosion was on the front, above windscreen. The van was sent away to a specialist body shop in Southport for 2 weeks. I didn't see the work done but I'm sure someone said that they'd taken the roof off.Where abouts was the corrosion for them to need to remove the roof.? When mine was done everything was done in situ.
I think that’s different. The front panel originally was replaced with a complete new panel that went further back into the vehicle but that was quite some time ago as it was costing VW over £4000 for repairs. After that they just did a plastic overlay. As yours is recent I would imagine it’s had an overlay panel fitted.Corrosion was on the front, above windscreen. The van was sent away to a specialist body shop in Southport for 2 weeks. I didn't see the work done but I'm sure someone said that they'd taken the roof off.
My drinking water pump once broke. Croydon SMG said they would need to take off exterior body panels and remove the water tank to replace the £18 pump. They quoted £1,500 all labour. I got another dealer to do it. They didn’t remove the tank but still charged £600 labour and failed to clip the pump in place so I had to do that myself the next day.They wanted nearly 500 just to remove the roof lining to access the panel. I feel ill!
So what currently isn’t working?Roof was removed by VW 5000 miles ago, for front corrosion issue, and has hardly been used since. Complained and now dealer says they'll pay for the part if I pay labour costs..£850 + vat. Is this fair?
Might be worth a call……So what currently isn’t working?
The roof went up after the corrosion repair a few times but has now stopped? Won’t go up ever?
VW say new control panel is needed? Is that the current situation?
I think most here would suggest taking out the panel as in the video I posted and check everything is connected. I have done that and replaced it as the lcd screen had died. It isn’t too difficult. The best thing then would be to borrow another one and see if that works. That’s really what VW should be doing for one hours labour max but sadly I appreciate that’s not happening.
If the control panel is controlling everything else fine and not showing any errors I would doubt it’s the definite cause.
I don’t know what others think?
I would advise looking at the dozens of roof threads and see what sounds familiar.
I imported my control panel pre Brexit from Germany and I think it cost £500. I then fitted it myself. Took 5 minutes and then another 10 minutes to change language from German to English! But I wouldn’t buy one unless sure that’s the problem. The pump is the other likely cause. There are other threads about that.
I think the control panel itself costs about 850. But the work for an experienced, maybe 15 minutes.Roof was removed by VW 5000 miles ago, for front corrosion issue, and has hardly been used since. Complained and now dealer says they'll pay for the part if I pay labour costs..£850 + vat. Is this fair?
Did they say the Control Panel had to be replaced, rather than the Control ECU?Thanks, I have gone ahead and told them to do the job, - I had no choice really- though I asked if i could have the old control panel back after the work is done...i just want to see what the issue was. Thanks for all your interest and input here.
