N
nigelknight
- Messages
- 1
We've had 2 occasions where the control panel displays that the roof is up when it is fully closed. This is accompanied by a ticking noise just to the left of the control panel (no motor noise) and the roof cannot be operated either up or down. If driven, the roof up audible warning sounds. Also the roof symbol on the control panel flashes, which according to the manual means the hydraulic fluid is too hot, even though the roof hasn't been used.
The problem first occurred when trying to put up the roof after arriving at a campsite. The roof didn't open at all. The second was when just turning the engine on for the daily commute.
On each occasion the fault was cleared by removing the fuse for the pop up roof from the fusebox and then putting it back, i.e cutting and then restoring power to the roof. The roof also then worked properly and no ticking noise.
The van is going into the VW Van dealer for it to be looked at, as the warranty expires in 2 months . I'm not altogether confident about this though as they didn't know where the fusebox for the relevant fuse was. I had to show them. So if anyone has experienced this fault and has any answers, I'd be grateful for a reply.
