Cooling problem California 2006 T5
Roar
Roar
Norway
T5 Cali on order
Hello.
I have seen in threads that some have the same problem.
Mye Cali suddenly stopped cooling while I was driving. I have red the threads and checked the fuses under the ashtray two fuse holder, under the driver seat one fuse holder and beside the battert one holder.
Do anyone know what else I can do?
Are there more fuse holder?
I am om Italy and it is HOT....
Roar
Hello.
Roar
Could you give a little more information.
Which vehicle? Your Avatar says T5 Cali on order, and 2006
Which “Cooling” are you referring to, Fridge, AirCon or Engine?
Håpefullt I can give more infomation.
I have a Transporter California T 5 mod 2005.
It is the AC that suddenly stopt working while driving. The butten I push is marked with econ, and it is probebly ac.?
Have you had the AirCon recharged every 2 years as it is supposed to be?
Has it ever worked? If it has did it suddenly stop working?
Do the Heater fans work?
I have har it før 6 mnd. And I do not know if it has been recharging.
All the fans is working. It stoped suddenly while driving.
I have checked all the fuses as I have described in earlier threads.
Roar
You should read out fault codes. It’s unfortunately really common to have leak in the air condition system. When there is to low pressure in the system the car will lock the ac compressor and ac will not work anymore. If so, you need to find the leak, fix it and recharge the system with new coolant medium.
Sometimes if your leak is really small (and you still have some coolant medium in the system), you can unlock the ac with diagnostic system (I use Ross tech vcds) and use the aircondition with light to moderate load. If you lucky it will function for a couple of weeks.
...And the econ button (economy) will actually disconnect the aircondition.
Thanks for all advise. I will try a vw workshop to morrow..
Roar
The VW work shop did read out fault codes and the problem was there.
They have solved the problem but they could not delete the fault code.
So my problem is solved, I am happy and it did not cost much.
Roar
Roar
Thank you for letting us know. Any idea what the actual problem was and the Fault Code?
Hallo
I'm not sure about these codes. I adhere to the invoice. There is a code at the bottom maybe that's the code?
Anyway, what thay have done explained in the invoise.
smgcowfoldparts
smgcowfoldparts
James Malone
5K
Russell Barnes
Russell Barnes
bangorlad
8K
Stewart1150
Stewart1150
