Works on my 2014 T5.1 and the T6.does it definitely work with the cali as amazon says does not work?
I have exactly the same issue. I swivelled the front seats yesterday and the airbag warning light came on again. There's no point in checking under the seat as I cannot reset it without the diagnostics tool.Can anyone tell me if this Autoscanner works on the cali SE 2011 as i have an airbag light persistently coming on from cable under the seat. I have borrowed the scanner but can't seem to get it to work it comes on but just says error after each scan. Any advice appreciated.
This is the one I use.I have exactly the same issue. I swivelled the front seats yesterday and the airbag warning light came on again. There's no point in checking under the seat as I cannot reset it without the diagnostics tool.
This happened the first time only recently. When I took it to the dealers they said the wiring had pulled apart as a result of my reclining the passenger seat!!! They then tried to charge me as it was "an adjustment" and therefore not covered under the Factory Extended Warranty. After further "discussions" they agreed to cover the full costs.
To be honest, I am rapidly losing confidence in the front seat airbag wiring. I'm now reluctant to recline or swivel. Every time it happens, it results in a long time wasting trip to the dealers, an argument and a dissatisfied owner.
I'd better get one of those gadgets ASAP. Our Cali is a 2016 T6 Beach. Can anyone please confirm what the name of the correct device is to order and where from?
Many thanks.
Thanks WG,This is the one I use.
Read up about it. I believe certain functions are free/built in and others are via an Annual Subscription. There are others but this is nice and easy to use.
https://www.amazon.co.uk/dp/B00YVHGTBM/?tag=eliteelect-21
Yes.Thanks WG,
I'll get Mrs B to order one asap.
I assume that you can reset faults warning lights, providing the fault has been rectified first?
Many thanks.
Works on my 2012 SE.does it definitely work with the cali as amazon says does not work?
It should work on a 2011 (they worked on my 2007 brera), there is a thread of VCDS and Carista owners on the forum, worth a look if anyone is nearby so you can get a test.As far as I can tell the Carista does not work on the older T5's
