Diamond shape socket advice please..
Q
Quogirl
Guest User
Hello all,
Sorry for this probably simple question!
The diamond socket I gather, is the inverter output so you can run 240v low current devices without mains hook up.
What is classed as "low current"? i.e. what wattage or voltage do I need to make sure I keep under to be safe?
Thanks!
As long as it doesn't exceed 150 watts
You should be fine
Thanks!
What sort of appliances does that usually cover?
Small things like laptops most appliances will say we have some portable hair straighteners that are 90 watts and work fine
