MyrtleMoo
Hi all,
I tried searching and found one thread with a similar problem but no conclusion: https://vwcaliforniaclub.com/threads/diesel-heater-problem.47405/
Occasionally, on our MY22 T6.1 Ocean, the diesel heater will silently fail to start. I'm curious if this is a known problem or a "normal" gremlin, or if it's something I should chase with VW while still in warranty. I'm not sure how useful a VW dealership would be investigating it because it only happens now and then (maybe 3 or 4 times in a year of use) and I can't reproduce it on demand.
Here's what I've figured out so far:
* If I try continuous heating (my normal mode of use), it will light up the orange heater indicator and display "please wait". After maybe 20-25 seconds it'll just silently switch the indicator back off, no apparent sound or action at all from the heater itself. Repeating this a couple of times gets the same effect.
* If I try heat immediately, it will do the same except this time it gets stuck in a loop continuously cycling to "Please Wait" and giving you no opportunity to abort it (and meaning you can't use the control panel to lower the roof!!). The only way to get out of the loop is to pop a fuse or press and hold the "off" button on the heater remote.
* In one instance, driving away and trying again at the next campsite has worked fine. In another instance, just leaving it a minute and trying again has worked.
* Batteries have always been full, tank always plenty fuel, and it's also happened while on hook-up.
* No error message or anything displayed, only the "please wait"
* It's happened even when the heater has been used perfectly fine the night before, and also when the heater has not been used for a few weeks.
* The heater has worked perfectly fine many other times and does tend to get a run at least once a month, though this last time it happened it hadn't been used for maybe 3 weeks and will have been starting fully cold.
Anyone got any light they can shed? Anyone had a good experience dealing with similar intermittent issues with VW garages? I'm up in Newcastle and the few encounters I've had with Lookers VW up here haven't filled me with a huge amount of confidence that they know much about the cali. Or is it all nothing to worry about and it does this now and again?
