stew
Hi,
The 'Battery' warning light on my T5.2 is lit up but only very dimly. I noticed it since it has gotten cold (-4C overnight). With the ignition on before starting, the light is very bright, so the bulb is working fine.
I fully charged the battery overnight and it still shows.
With a multimeter, the voltage across the battery when the engine is running shows 14.55v and at rest, the battery has shown anywhere from 12.38v to 12.56v (all times at least 3 hours after stopping the engine). Strangely, if I keep the multimeter probes on the battery, the volts gradually increase, about 0.1v every few seconds...
From a little bit of googling, this appears to show that the alternator is at least working and the battery is not yet bad, but not in peak condition either. It is the original one and at least 7 years old.
Does anyone have a clue why the light should be on, albeit dim? Does this signify something other than when it is bright? The manual says nothing about varying levels of brightness.
Thanks!
Thanks!
